Fiat TC - odd cam lobe wear
fiat124sedan
Post by fiat124sedan »
Whilst going through head gasket replacement, I found the following and I had absolutely no idea what might be to blame.
First thing I noticed was the scoring on the cam shim. So I looked at the cam to see what might have caused it and noticed that the cam lobe was worn to an edge!
I consulted with Guy and he suggested I put it up here for all to see. His suggestion is that it may be the result of dry startup - could be from the recent time that my car was pulled onto a trailer-truck, forcing all the oil away from the front of the cam boxes...or it may have just been I did not put oil diligently into the cam boxes once upon a time in a build...but then, that's not really possible as the oil filler cap on a Fiat TC is right above number one exhaust cam lobe - the one that's worn in this pic...
Food for thought.
Cam lobe - see how it has worn to a point!  The sharp edges are what tore the grooves in the shim below
Worn exhaust cam.JPG (251.26 KiB) Viewed 4059 times
Number one exhaust valve cam bucket shim
Worn cam bucket shim.JPG (316.78 KiB) Viewed 4059 times
Post by sumplug »
Looks like you have been running with too little clearance, wrong timing, blocked or partial blocked oilways, or a combination of all or some of above.
Running with the wrong oil filter can drain the cam boxes dry.
!t must of been making quite a noise whilst running to cause that damage!!
Was the cam box dry or wet with oil on removal of the cover?
Andy.
