Throttle body flow?
Posted: January 16th, 2007, 2:33 pm
It is in relation to this in the theory section, I thought it best to start a new post.
viewtopic.php?t=679
I am confused in the calculations you square the diameter to work out the surface area. Should it not be this calculation?
Area = Pi times the radius squared (A=pr2)
So radius is half the diameter (ie to the centre - out) so for a 32 and 40mm throat.
32/2= 16
3.14 x 16^2 = 804.247719318987 and not 1089mm?
so 32mm = 804.25
40mm = 1256.64
But with turbulance being the biggest problem in this design how comes the flow calculation is not taking this into account?
Gas speed being fastest in the centre is where you have the biggest obstruction, ie the butterfly, the screws etc.
viewtopic.php?t=679
32/2= 16
so 32mm = 804.25
40mm = 1256.64
