Vortex, swirl and intake flow
Posted: October 18th, 2006, 1:51 pm
by Piero
Just a stab in the dark, as I was reading through a tuning book and whilst looking at a drawing of how the gasses move in the port and mainly around the valve, I struck apon a thought about cutting grooves in the inlet tract, to create a swirling effect in order to even out the flow rate around the vavle.
It is only a thought, and I have not thought about the pros and cons much either.
Just wondering if its worth spending any time on the idea, or is it a no no, or has it even been done?
Posted: October 18th, 2006, 2:06 pm
Doesn't need it and it will probably upset the flowrate, the TC uses squish bands to generate swirl; try the site search facility (bold), there is a fair it on it.
Best not to tamper with what the head/engine comes with frankly.
Posted: October 18th, 2006, 2:25 pm
by Piero
I was thinking more of the inlet track, to keep gases even around the back of the vavle/stem.
Looking at the drawing, it shows gases moving faster on the long side of the inlet track, if gases could hit the vavle evenly, I thought it might flow more.
Was even hoping the vortex might help pull the gas alonge.
Posted: October 18th, 2006, 2:39 pm
As with all production heads there is a finite amount of flow you can get, sometimes determined by proximity of coolant galleries. I have tried everything I can to get ultimate inlet flow on the TC head by trying to get good flow right around the valve, what you're suggesting would not work, sorry.
Posted: October 18th, 2006, 2:43 pm
by Piero
O well, there goes that thought.
Thanks Guy
Posted: October 18th, 2006, 2:48 pm
Yes, a vortex is the last thing you want in an inlet port, I spend most of my time trying to get rid of them. Vortex = turbulence = flow loss.
'Swirl ports' by the way, in case you don't know (some might not anyhow) have nothing to do with flow efficiency, they are designed to promote fast burn.
Posted: October 18th, 2006, 2:55 pm
by Piero
So what would you say is the best way to get the gases moving faster in and around the inlet vavle, along the shortest line of the inlet track.
