Just a stab in the dark, as I was reading through a tuning book and whilst looking at a drawing of how the gasses move in the port and mainly around the valve, I struck apon a thought about cutting grooves in the inlet tract, to create a swirling effect in order to even out the flow rate around the vavle.
It is only a thought, and I have not thought about the pros and cons much either.
Just wondering if its worth spending any time on the idea, or is it a no no, or has it even been done?
Vortex, swirl and intake flow
Piero
I was thinking more of the inlet track, to keep gases even around the back of the vavle/stem.
Looking at the drawing, it shows gases moving faster on the long side of the inlet track, if gases could hit the vavle evenly, I thought it might flow more.
Was even hoping the vortex might help pull the gas alonge.
As with all production heads there is a finite amount of flow you can get, sometimes determined by proximity of coolant galleries. I have tried everything I can to get ultimate inlet flow on the TC head by trying to get good flow right around the valve, what you're suggesting would not work, sorry.
Piero
