Fiat 124 Weber 38 DGES
TVST*R
My engine is a stock 1800 with Mark Allison's Python Header and exhaust.
With this Weber installed, I am getting a pretty severe flat spot at around 1500-2000 rpms off the line. Otherwise, pulls very strong and wayyyyy better than my old 32/36 (for sale).
Any ideas as how to fix this?
Thanks!
Thanks!
1977 Fiat 124 Spider
Sorry, but that carb is a hopeless choice. I have read more 'guff' about it being suitable for every car from 1200cc up than any other carb. It's not, and for what it's worth the only engine I would ever use it on is a 3 liter Vee engine - where each barrel feeds a separate bank - or something like that.
Assuming the header is not way too short the flat spot on pickup is almost certainly due the synchronous operation of the throttles. Meaning they open together at the same time and so the airspeed drops too much on small throttle openings to give a good fuelling signal (insufficient depression).
Change it to a carb with 'progressive chokes' (well, actually it's the throttle plates that are progressive but no-one calls them 'progressive throttle carbs'..) and the 32/36 DGV series with electric choke (oh dear - cold start device..) DGEV, water fed auto DGAV or manual DGV. That carb has 8% bigger choke area than than the OE carb and will give you the best power and torque you'll ever get from a TC on a single carb setup.
TVST*R
I don't want to sound 'clever' about this, but you're not the first that has reported this effect with that carb. Let me turn it around. A great carb would be one that bolted on and produced everything you wanted!
A flat spot like that may be 'liveable-with' (being who I am it would never be so for me) and sure you can drive through it but the effect it can have on rings and bores due to adverse fuelling can be quite serious. And I figure that you would not have mentioned it if you did not feel it was significant yourself.
I don't think you will get rid of the flat spot.
TVST*R
HFStuart
Yes it does, but just talking a moment ago to the helpful Andy Gray at Webcon UK about this on your behalf the DGV carb is not suitable for transverse operation due to the layout of the float. Like the problems you can get putting DCNF in a RWD application you are as likely as not to get fuel surge on corners. So my advice is avoid it.
Whilst the 32/36 DGV (26/27 chokes) series is a great performance upgrade on the, say 2 liter RWD Fiat TC compared with the standard 34ADF (24 chokes), there was never such a carb made that would bolt straight on to the transverse (FWD) Lancias originally fitted with, as you say, the 34DMTR (25/26 chokes). If your Lancia carb is worn out, Webcon do have stock of those by the way.
HFStuart
