I need your help.
Actually I'm building a 1602cc OHC engine with two DCNF's carb's.
I think I show some pictures from the engine:
Head:
It's a 1.5 SPI Uno head with bigger inlet valves (39,5mm from 1.6 Tipo).
The pistons:
Lancia 1.5 pistons - compression height of 35mm and 0.6m oversize
The block:
It's a 1.5 SPI Uno block.
Crankshaft is a 1.4/1.6. To get 1602cc with the bore of 87mm.
The rods:
Uno Turbo Mk1 without CAT - shall be forged...
I have a piston overstand of 1.5mm.
I get buy three gaskets. In a thickness of 1.74mm, 1.8mm and 1.9mm.
My problem, are 0.2mm from piston to head enough?
The valve pockets have a volume of 5ml (I have to make them bigger for the big inlet valve - the engine gets a 316‚° camshaft).
So I have a CR of 11.48:1 with a distance of 0.2mm.
What are your experience with this? Shall I better make a distance of 0.5mm or bigger?
I think about this small distance because this makes a very small combustion chamber and so I have some HP's more than with the same CR and a higher distance. But I don't want to bump the piston again the head.
Thanks for helping.
I hope the style of the thread is ok :)
