Beta VX supercharged , Carb upgrade, Accelerator pump cam
keithvx
Post by keithvx »
Hello Guy
i have made a short path manifold for weber DCNF 44 carberator upgrade. It is now mounted and operational . ( Yet to be tuned ).
I note that the accelerator pump cam profile is quite different from the origional DCA 5 / 250 36 weber carb.
Question: Disregarding all other tunable componants , ie pump jets .
Would you retain the cam that came with the DCNF 44 . Or
would you transfer the DCA 5 cam on to the DCNF 44.
Note : At this stage I have no information on what vehicle the
DCNF 44 came from
the cam on the left is the DCNF 44 item.  on the right is the origional DCA item
Keith, use the 44DCNF cam.
Your nice pictures sent to me by pm please post here - unless you wish to keep them confidential of course.
keithvx
photos of dcnf 44 and custom manifold
Post by keithvx »
thanks GC.
Manifold and carb set up , as per photos
I am having 32 chokes made and would very much appreciate any advice on jetting etc for beta vx race motor /weber DCNF 44.
regards keith
Nicely executed manifold Keith - sure gets my seal of approval!
I'd like to hear about your plans for filtration and ducting etc. My guidance available as ever.
Jetting I will come back to, bit tied up at present.
keithvx
Induction for DCNF
Post by keithvx »
Yes induction is a challange. When running the standard carb and manifold i took the normal cold air feed from over the radiator and feed it to custom air box via ducting . Duct fed to inside of k&n filter and airbox took air from outside of filter to carb top . Box designed to sit on carb but bulk of filter housing sat to the side and fed from under box.
However this time i may feed from behind head light. iIhave moved radiator sideways and have moved power bump in bonnet to over the super charger. i will see how much height i can get before making a decision.
regards keith
ps . Gave up waiting for 32 chokes so made my own last night from a set of dellorto 32 chokes. Was not as hard as i thought. Found out in the process that although carb has 44 stamped on it , it is actually a 42 . ?
standard (carb / manifold /bonnet )induction for my vx beta race car
