Destroyed injector after cleaning ?!
DamirGTI
Post by DamirGTI »
Hi Guy !
Yesterday i was cleaning my injectors on ultrasonicaly machine in one car mechanic workshop and they destroyed one injector - after cleaning i have fit injectors back , start the engine and it was running on 3 cylinders (one injector is dead , i've check that ) , now i've fit another set of my old low flow injectors and the engine works fine on all 4 cylinders ..
Please , can you explane me how is this possible to destroy injector during the cleaning process ?
Thanks !
Damir
Acki
Post by Acki »
Maybe the filter is damaged in the injector.
Blockage by tiny dirt particles usually - it's hard to damage an injector any other way.
DamirGTI
Post by DamirGTI »
Hi !
So what should i do next Guy ? try to clean all of them one more time , or replace this filters inside the injectors ?
How can i change/remove filters ? i see them inside the injectors , but they are really tight fitted I'm worried that i don't damage something , with what should i pull them out ? With a screwdriver or ?
I've found one article regarding ultrasonic injector cleaning ¢‚¬Å“ very interesting read :
http://web.archive.org/web/200306301240 ... TRASND.HTM
Thanks !
Damir
Sorry, never done it, always regarded anything to do with injectors as a Bosch specialist job.
DamirGTI
Post by DamirGTI »
Hello Guy !
Ok. , thanks !
Kind regards
Damir
