At last , i have an project to make :)
It's a straight 6 cylinder head , 4 valves per cylinder , 2,979 cc 230 hp @ 5,900 rpm from BMW E46 330i car .
Engine code : M54B30
From a rough eye/finger inspections of the ports and valve pockets , i have to say i'm pretty disappointed by the port casting/indexing as being a BMW head i supposed it would be much better . So , i see here's a lot of job and also , good end result when finished with the porting .
Inlet ports are a bit narrow , lots of sharp edges inside the valve pockets and i think i'd lift up the inlet port roof around the valve guide as it seems to me somewhat bad , which i think will improve swirl effect .
Exhaust ports , even more narrower than the inlet all around on the port entry - lots of material till the gasket sealing area .. and again sharp edges inside the valve pockets (but not as much as on inlets) , and similar "hump" around valve guide .
SSR (Short side radius) , not bad on both the inlet and exhaust , think i'll do just some smoothing here ..
Combustion chambers , nice and smooth finish from factory .. just some sharp edges around valve seats which needs removing and smoothing , so not so much job here :) (not sure if it's worth doing valve unshrouding ?)
The head i'm preparing is for one very good friend of mine , so i want do it as best as i can !
Modifications further will be higher compression ratio , he said to me that he wants to retain standard valve sizes (will measure) , standard camshafts , inlet and exhaust manifold . So just porting and cutting multiple angle seats .
Im currently in processes of dismantling the valves , cleaning etc. .. when i finish that i'll post pics of the head .
Till then , i have some cut offs of this the same head :
Any advices much appreciated :)
Damir
