Can anyone ID this LS differential?
Client of mine wants to sell this limited spin diff unit but we don't know what it's for. It was sold to him as being for a Fiat 131 TC 2 liter but it isn't.
I think it's unused. Thanks to anyone who can advise or who may be interested in buying it.
Maybe 124 live axle or Gp4 IRS type 124/131?
LS unit_not 131 TC.JPG (480.19 KiB) Viewed 16015 times
LS unit_not 131 TC (1).JPG (460.42 KiB) Viewed 16015 times
LS unit_not 131 TC (2).JPG (482.04 KiB) Viewed 16015 times
LS unit_not 131 TC (3).JPG (440.64 KiB) Viewed 16015 times
Re: Can anyone ID this LS differential?
Post by TomLouwrier »
Sorry. Could be anything from those pictures. Unless someone actually has one like that lying around and recognizes some specific feature, little chance.
With some figures for main dimensions it would be feasible to look for a similar unit in catalogues from Quaife etc, that would lead to the correct application.
well it is definitely Fiat - has the Lobo bolts.
Urbancamo
Post by Urbancamo »
If you can measure things like bearing journal diameters, their length to each other and ring gear bolt pattern, I can compare them to Lada/Fiat 124 ones easily.
These pictures alone won't tell much. You can't even tell of what kind of LSD it is. I would guess it is clutch pack one, but I'm not sure.
-T
GC_25
mickwood
Post by mickwood »
GC - if your client could give key dimensions, i could check if it is 124/131 G4 -
First impression, however, is that it is not - i think it looks to have output drive for shafts with only 24/25 splines (pretty hard to count from those pictures) which is way smaller than 131
M
Maximum diameter approx 135mm. Length approx 148mm. 22 splines. There are some very faint inscriptions on the widest shaft part. It reads something like BP 826679 TF 383 T 266
nabihelosta
Post by nabihelosta »
Guy
Any chance that the inscription could have been "BR" not "BP"??
Then you can check the serial number and dimensions with Bacci Romano maybe..
Nabih
HORSEPOWERunlimited
Thanks - I had a look thru Fiat at Bacci but they don't use a simple 'BR' coding and as faras I can tell none of the diffs look like this one..
nabihelosta
Guy
By maximum diameter, you mean the extreme outer diameter of the drilled section where the bolt holes are, or the machined diameter where the inner face of the crown wheel lays and centers?
If second answer is the case, than we can start narrowing the search for Fiat models with a 5.25" crown wheel size. Pretty small no?
N
HORSEPOWERunlimited
Thanks - but 'hold-fire'...
I've suggested the owner now write to Bacci with photos!
