Fiat 124 spider 1972 1608 leaking cam seal
Question and answer direct with GC. Competition engines and 'live' projects only. Good photos to illustrate your post are expected.
Postby bsx » Tue Jun 12, 2012 2:35 am
Hello, I just completed a rebuild of my 1608 engine with:
new gasket / seal set
piston rings
valve seals
etc...
I am keeping everything stock, rebuild went well except that my cam exhaust seal is leaking behind the front pulley. The seal I obtained from my supplier was mfg. by AKRON, I obtained a new seal mfg. by BECK/ARNLEY and still have the same problem.
No problems are seen on a close visual inspection of seal surface and my oil pressure is within normal range.
I was told that this a well known leak point and may have to live with it, I never had the problem before the rebuild and I am not happy with that answer. Can you provide a seal that may correct my problem? Any information would be appreciated.
Thank you
bsx
Re: Fiat 124 spider 1972 1608 leaking cam seal
Postby Guy Croft » Tue Jun 12, 2012 8:37 am
This is most commonly where the block face or head face has been 'dressed' with carborundun paper or similar and debris has become trapped in the oil feed holes to the head. There are 6 on the block. The debris gets forced into the cam front journal housing by oil pressure and tears into the cam nose, housing and seal. Leak from the cam seal generally results.
Postby bsx » Tue Jun 12, 2012 2:00 pm
Thank You for your fast and informative response, could you suggest the best way to correct the problem or is another rebuild in my future?
Thank You
bsx
Postby Guy Croft » Tue Jun 12, 2012 3:41 pm
Pull the camboxes and remove both seals, polish the cam journals with light oil and fine Scotchbrite, clean with brake cleaner or similar solvent and do the same to the camboxes esp front journal housing. Reassemble with new seals but be sure to use OE type with polymer coated case.
Sorry I am in a hurry - I can offer pics tomorrow if_u_need.
Postby bsx » Wed Jun 13, 2012 2:03 am
Thank you for the helpful response. At your convenience, If you could post pictures it would be greatly appreciated.
Thank you again
bsx
Postby Guy Croft » Wed Jun 13, 2012 11:23 am
Photo captions should tell you most of the story..
Worth mentioning that in addition to the debris cause I remarked on already, dry start or over-tightened cambelt can cause scuffing damage too. Always use engine oil and a tiny bit of molybdenum grease in the cambox bores on reassembly. Naturally the seal inner diameter & cam nose needs a bit of oil on it too.
Great way to polish the cams
How to polish a cam. Fluid is Jizer but oil will do..jpg (61.49 KiB) Viewed 1234 times
the critical front journal housing in the cambox. They will tolerate a fair bit of scuff and scoring but always polish them up with Scotchbrite. We use a simple tool driven by a drill - a length of wooden dowel with the end split to wedge Scotchbrite into it.
FC camboxes overhauled & ready to build (1).JPG (89.65 KiB) Viewed 1234 times
example of a polymer coated seal. As a a rule I use OE ones that - similar to these from Dupont. The early seals which have a plain steel case always end up leaking and don't stay in place near as well.
GC 042.jpg (112.93 KiB) Viewed 1234 times
pair of camboxes ready to build - decarbonised, beadblasted, deburred all over and mating faces dressed with a fine stone plus all journal housings polished with Scotcbrite. Whilst the cam should be rotatated in DIRECTION OF ROTATION - CLOCKWISE, housings should be polished contra-direction of rotation so as not to 'raise the grain' of the metal.
EU_cams and boxes, deburred and fully prepped ready to build.JPG (108.61 KiB) Viewed 1234 times
Postby Urbancamo » Wed Jun 13, 2012 11:44 am
The thing worth mentioning is straightness of the seal in the housing. This size oil seal can tolerate only 0,20 mm diagonal declination (hope my words are right ones). After that it's gonna worn out fast and leak for sure. So make sure the seal is perfectly in place and straight.
As Guy also mentioned, Viton seals are the best. They can tolerate up to 200 deg. C of heat and thet don't really deteriorate. I'm also used NBR (nitrile rubber) ones with great success in street use when stress is much more lower than in racing.
Book #432
Urbancamo
Postby Sealord69 » Wed Jun 13, 2012 9:37 pm
... As a a rule I use OE ones that ....
Hey Guy thank you for sponsoring my company. We produce the OEM types you will find cfw on the OEM or Corteco on the aftermarket types. They are out of the same tooling.
For user who are interested to learn more radial shaft sealings.
Technical handbook: http://www.simrit.de/files/000013AE.pdf
Catalogue: http://www.simrit.de/files/00001387.pdf
Nils
Sealord69
Return to GUY CROFT Q & A
