My Fiat 2 liter rebuild that started as a head swap!
parrish
I had bought a replacement head that had been worked on! fitted with GC stage 3 cams and had planned a quick head swap, that was last September.
Once the head was off i decided to remove the short engine and have a look at some other areas, one thing led to another and i ended up carrying out a complete rebuild, new Crank and rod shells, new piston rings (honed cylinders), modified auxiliary shaft as per G.C. recommendation, new oil pump, G.C. 1" belt conversion, thermostat in head modification, all gaskets, tensioner bearing, head gasket bolts, sump studs and bearing shells supplied by G.C. along with a wealth of advise and information extracted from G.C. book and several phone calls/e-mails made to Guy himself for advise on measurements etc.
Today it started first time, some pictures.
- block reasembled.
- P2261415.JPG (142.05 KiB) Viewed 30161 times
- Finding TDC
- P2261424.JPG (143.77 KiB) Viewed 30161 times
- New TDC Bracket and crank marker
- P2261426.JPG (144.41 KiB) Viewed 30161 times
- 36-1 trigger wheel.
- P2261430.JPG (135.02 KiB) Viewed 30161 times
- GC supplied head gasket and the all important 'HOW To'
- P2261431.JPG (145.67 KiB) Viewed 30161 times
- Cylinder head dry fit for piston/valve clearance.
- P2261436.JPG (135.81 KiB) Viewed 30161 times
- Plasticine cut and measured (and recorded)
- P2261435.JPG (149.94 KiB) Viewed 30161 times
- Dry run fitting of inlet side.
- P2271459.JPG (152.94 KiB) Viewed 30161 times
- I built it so i put my name on it!
- P2271461.JPG (146.86 KiB) Viewed 30161 times
Parrish 366
4v6
Re: It started as a head swap.
Nice project.
Its always the same though, you start off with something small and end up going the whole hog rather than do a half a job, worth it though.
Tony Warren. GC #96.
Well, readers - I think Steve deserves some praise for this, no??
LanciaNut69
Isn't that always the way? As the saying goes, if a job's worth doing........ Nice pics and good to hear it started first time, although looking at the prep, I can't be that surprised that it didn't!
Well done
Darren
Well done
Darren
__________
Book #435
Book #435
Re: My Fiat 2 liter rebuild that started as a head swap!
Have amended the title slightly to draw attention to this thread.
I may be wrong but I don't think poster Steve Parrish has done one of these before.
PS my word censor changed '3 ch-e-ers' to '3 thank you'
Abarthnorway - Remi L
Hi Parrish!
Serious job for a quick headswap I must say.....:-)
As my now deceased grandma used to say:
The highest degree of laziness is; to do things properly; right away.
Congratulations on a beautiful engine!!
What throttle bodies are You using?
How did You make the plenum?
How much do the pistons protrude over the block?
Cams 3D or 3A?
I would also love to have a closer look at Your red Abarth 131 body - at least thats what I think I see in the background....
Best regards
Remi Lovhoiden
Cams 3D or 3A?
Best regards
Remi Lovhoiden
GC_45
parrish
Jenvey 40mm throttle bodies.
Cams GC 3A.
Plenum is from a Nissan turbo, modified & welded.
Pistons are normal 130 TC, do not protrude above the block except for the crown.
Here are some pictures of the car that the engine now sits in.
Cams GC 3A.
- P3261304.JPG (134.61 KiB) Viewed 30040 times
- P3261302.JPG (146.54 KiB) Viewed 30040 times
- P3261303.JPG (145.36 KiB) Viewed 30040 times
- PA100693.JPG (146.13 KiB) Viewed 30040 times
- Side view[1].jpg (128.73 KiB) Viewed 30040 times
- My garage!
- P6140838In Garage[1].jpg (142.31 KiB) Viewed 30040 times
Parrish 366
WOOWW!
Did You do the bodywork Yourself?
- its a beast!!
Remi
- its a beast!!
Remi
GC_45
parrish
Car required a lot of body repairs before Tarmac body kit was fitted (From Middle Barton Garage).
After welding repairs to the chassis new front and rear panels, sills, front wings and 2 new doors were fitted, roof gutters removed.
As you can see it was a full windows out rebuild of the body, work was carried out about 7 years ago in the UK by a local garage, as the car lives in Spain (no road salt and little rain) the body work is as good today as it was 7 years ago.
Other modifications include, Fiat Turbo vented front disc conversion, uprated shock absorbers and springs, polly bush suspension, full cage, and of course the Omex EFI/ignition.
- 3.JPG (39 KiB) Viewed 30011 times
- 4.JPG (40.06 KiB) Viewed 30011 times
- 5.JPG (39.64 KiB) Viewed 30011 times
- 6.JPG (39.05 KiB) Viewed 30011 times
- 7.JPG (39.43 KiB) Viewed 30011 times
- 8.JPG (38.79 KiB) Viewed 30011 times
- 9.JPG (38.67 KiB) Viewed 30011 times
Parrish 366
I think Guys remark about deserving praise is well in place. It's looking fantastic. I love the bold orange on the car. Is the engine running yet?
LanciaNut69
Seconded, wow! Beautiful looking car and I love the 'contemplation room/garage'!WhizzMan wrote:I think Guys remark about deserving praise is well in place. It's looking fantastic. I love the bold orange on the car. Is the engine running yet?
Darren
__________
Book #435
Book #435
parrish
Engine started first time, followed G.C advised start up procedure, now run up to 5000 rpm static.
Parrish 366
Brit01
What a transformation! Great work on the bodywork (engine too of course).
Love the wheels. Perfect match.
Beautiful engine, and of course you just got to love the colour of the car! Fiat Racing Orange, as they did it way back in the seventies.
That same colour is on my Spider, people get their sunglasses out when they come near it ;-)
I'd say you have it in your living room, right? (I would if the missus let me...)
parrish
Tom, this is my garage!
Not the living room.
- PA100673.JPG (141.62 KiB) Viewed 30078 times
- PA100685.JPG (130.36 KiB) Viewed 30078 times
- PA100762.JPG (148.28 KiB) Viewed 30078 times
- PA100677.JPG (143.09 KiB) Viewed 30078 times
- PA100758.JPG (131.2 KiB) Viewed 30078 times
Parrish 366
