Fiat 128 model '72 -Stage 1-
federico_878
Hello my name is Federico. I live in Buenos Aires, Argentina
I present my car is a Fiat 128 model '72.
Engine SOHC:
-1100 cc to 1400 cc.
-Tipo's crank stroke 67.4mm
-crankshaft has worked the benches.
-forged pistons, bore 82.5mm and volume 7cc.
-polished rods, lightened, keeping your weight evenly between the 4.
-cylinder head gasket sheet thickness of 0.6.
-cylinder head: * ducts worked
*worked Heaven
* worked valve seat
*valves are developing a new
* worked valve guides
-Fiat 128 camshaft IAVA 1300cc 102hp.
-Megasquirt 2 only work spark.
-Weber carburetor 32 mm to 40 mm, original broadcasters.
-steel flywheel weight was reduced from the original.
-gearbox Lancia (Fiat 1, Fiat Tipo, Motor type in a few words).
-clutch: original plate, disc brake pads 3 and fixed center
Front:
-adjustable arm ball
-elastomer bushings are developing.
-original roll-bar
-shock compression and worked in expancion
-will work in the spring, reducing the height.
-wheels 13" original Fiat Uno Turbo
-undefined tires.
-disc brake and calipers Fiat Palio ventilated
Rear:
-is being re-designed
Interior:
-instrumental Fiat 128 IAVA 1100cc
-"torpedo" in the process of restoration
-steering wheel Renault R19 RTI Coupe (redesigned, obviously)
-seats, waiting for a surprise.
P.S.1: I apologize for my English is not very good. If you need to modify the post, no problems.
P.S.2:The photos go up tomorrow, I have them on this pc.
Engine SOHC:
*worked Heaven
* worked valve seat
Front:
-original roll-bar
-undefined tires.
Rear:
Interior:
federico_878
Re: Fiat 128 model '72 -Stage 1-
Hi, I brought some pictures of the car and engine parts.
Photos of the car when I buy it:
After changing some parts:
Reinforcement was performed on the body:
In the workshop of the painter
Work can be seen on the cranks:
Engine 1100 cc to 1400 cc:
Forged piston:
Reform to the command switch:
Sorry for my English not very good. And soon I will be counting as the next stage is made.
Should they have any questions ask me.
Byee
Forged piston:
Byee
federico_878
any suggestions?
Sorry Federico
been that busy lately hardly been able to write on the site at all. Doing my best.
Will look in on this one when I get a moment slightly longer than 2 minutes without the phone ringing.
In the meantime !! MEMBERS!! can we have a bit of enthusiasm for this super project from a friend so far away?
Ta
Ta
Brit01
I'm probably your closest neighbour being just across the rio de la plata (Pocitos-MVD).
You are taking on a big project there federico_878 by the looks of it. Total restoration.
Can you find parts easily in Buenos Aires?
From 1100 to 1400 is a dramatic increase. Are you working on this yourself or have technical assistance?
NineOneSix
Quite a project your taking on there! I love the old Fiats. Good luck with the project!
Oh and your English is fine, I would not worry to much.
federico_878
Thanks Guy.Guy Croft wrote:Sorry Federico
Ta
Is true we are close.Brit01 wrote:I'm probably your closest neighbour being just across the rio de la plata (Pocitos-MVD).
With regard to motor much in the market. Parts for the body there are varied quality and poor quality.
Don't understand what the "technical assistance"?
Thanks. This project takes me a long time...NineOneSix wrote:Quite a project your taking on there! I love the old Fiats. Good luck with the project!
federico_878
News:
Buy Fiat Uno Turbo wheels 13 "x 5.5".
Some pics
many pictures up tomorrow.
Some pics
Brit01
I can relate to you about the poor quality of products here in South America. I try to buy smaller/critical parts from Europe if I can.Is true we are close.
What I meant about "technical assistance" was that if you had help or are working on the car alone? Re-boring etc.
federico_878
Chris:
work alone in my car, sometimes I ask for help to colleagues / friends, if only I can not do.
Regards.
Regards.
podd37
Great work...kep us all informed
Brit01
Any updates Federico?
Been a while since we've heard anything new about your 128.
federico_878
I get some time today and tell them the news
