Page 1 of 2
Fiat Uno 1.4 Turbo
Posted: January 8th, 2007, 12:53 pm
by Lui
Hi all
This is my car:
Suspension:
Yellow bilstein and H&R - 60mm springs
Engine:
-opel omega intercooler (double size than stock)
-greddy style blow off valve
-HKS air filter
-stock exhaust without cat and with spoon n1 end muffler
- LE 3.2 Jetronic engine management with perfectpower smt6 piggyback (fuel and ignition)
I'm installing:
-T25 turbocharger .49 (compressor) .64 (turbine)
-240cc injectors
I'm waiting for turbine housing now, and then i'm going to tune the engine with 1 - 1.2 bar boost
Posted: January 8th, 2007, 3:36 pm
Hi Lui!
Nice car! No idea what half those numbers and names mean but sounds impressive!
Posted: January 8th, 2007, 3:48 pm
by Acki
T25 can max 1.4bar boost. Check the pressure direct after ther charger.
Posted: January 8th, 2007, 4:08 pm
by Yugo_Turbo
Lovelly car and wonderfull wheels.
True oldschool.
Are you having any problems using that blow-off,like bad idle,slower spool-up after the throtle has been realesed and then pressed again?
thank you!
Posted: January 8th, 2007, 5:45 pm
by Julian
Lui, very nice car but I have just a small observation - check the angle of the harness from the back of the seat to the mountings. From the photos it appears to be quite a steep angle and that is very dangerous, especially if the seat is mounted onto the original Fiat seat mounting points.
Ideally the straps should be close to horizontal from the back of the seat to its mountings.
The absolute maximum angle (from horizontal) is 45 degrees, anything more than that is regarded as dangerous.
If I'm wrong and it is just what it looks like from the photos then please ignore me!
Posted: January 8th, 2007, 6:18 pm
by martin.g
Hi Lui!
It's nice to see man from my ground. I'm very like UT and your car is very nice. Simply, fast and without any body-kit's, etc... Keep that way!
Greetings for all, because it's my first post on this forum. Soon I will try to introduce my old car ¢‚¬Å“ Fiat 126p build for amatours rally in Poland.
Sorry if my english is wrong to read, I'll try to learn more ;).
Best regards,
Martin
Posted: January 8th, 2007, 9:52 pm
by Lui
>>Julian
It is only looks that, it is quite more than 45 degrees (according to FIA J appendix)
Shoulder straps will be fixed to the safety cage that i'm going to install soon
I'm going to compete in hillclimb events in Czech Republic this year.
Posted: January 10th, 2007, 3:56 am
by Lui
Evrything work fine, it depend on the blow off valve type and spring tension.
I have membrane blow off valve with a quite hard spring and it works good,
Earlier I was using single and twin piston blow off valve. Twin piston valve is a better solution than single piston it have faster response.
Posted: January 10th, 2007, 10:37 am
by Yugo_Turbo
Thank you very much for information.
Posted: January 19th, 2007, 8:26 pm
by biz
Nice MK2
What wheels are they Lui?
Posted: January 22nd, 2007, 1:19 am
by SteveNZ
Nice Uno turbo!
You have similar engine modification to my Uno turbo. How well does the piggyback work? Do you have an air fuel ratio plot?
Posted: January 23rd, 2007, 2:10 am
by Lui
biz wrote:What wheels are they Lui?
INTRA 13" 6J, I dont know exact name.... They were silver with black spokes, but I like white wheels
SteveNZ wrote: How well does the piggyback work?
Problem with such type of piggyback is that it only control output of airflow meter signal, and it rather can make mixture lean than rich
so it is essential to install larger injectors or/and rise fuel pressure to make mixture suitably rich and then tune properly AFR on low revs and without boost
but
smt6 have a few advantages:
- ignition control
- boost / additional injector(s) / nitrous control
- it is very easy to install and tune (well known in Poland)
- low price ! (new - 110 pounds)
SteveNZ wrote: Do you have an air fuel ratio plot?
I didin't finish T25 conversion yet so I didn't start mapping.... (lack of time :/ )
Posted: June 25th, 2007, 3:28 pm
by Lui
@1bar and bit too rich AFR~10,5 on boost
Power on WHEELS:
Power on ENGINE:
any suggestions what to do to reduce turbo lag?
Posted: July 1st, 2007, 9:43 pm
by Acki
But the pipe from the wastegate on the manifold. But think about the surge zone (left area in the flow map) -> high exhaust pressure between exhaust valve and turbo.
Posted: July 2nd, 2007, 9:21 am
by Lui
Acki wrote:But the pipe from the wastegate on the manifold.
I don't understand what do you mean?
Compressor shouldn't work in surge even if I will have full boost 1000rpm earlier
