Jetting for Dellorto DHLA 40's on a Fiat 2L
Posted: September 4th, 2006, 2:17 am
Greetings from Australia Guy;
I have just discovered your new look forum/website and appreciate the help you offer.
I have a 2L motor in my 131, with extractors 4,2,1, mild head work and
a set of 40 DHLA Dellortos on a straight shot style manifold I welded up.
The car has been running like this for a while but I get the occasional back fire thru the carbs, with splutter when cruising at 2-3K rpm (idle to progression?)
I think they may be running a bit lean. They were straight from an Alfa GTV.
Can you suggest jetting to try for this setup? I'm sure the chokes are 32mm.
