Weber 44 IDF on Fiat-abarth 124CSA - stalling problem
Posted: August 31st, 2006, 12:32 pm
I am the owner of a 124 Abarth in stock engine configuration. Carbs are the stock IDF 44.
Car runs well except for a flat spot off transition, every time I press the gas pedal. It happens when I drive it or when I rev it, at a stop. Whatever the engine speed, when I accelerate, there it chokes, shakes a bit and then picks-up properly. I have had that many times with Webers in other applications and never figured out what the cause would be? Wrong idle mixture?
