hi to all ,
i need a Double plate clutch kit from a reputable manufacturer for a friend of mine which ownes a Lancia Delta integral 1992.
please let me know where to find one .
thanks guys ...
nassim131
Last edited by nassim131 on September 13th, 2012, 10:10 am, edited 2 times in total.
Nassim (Book#327)
Re: Double blate clutch kit
I don't know of a dual plate clutch that bolts directly Nassim.
nassim131
thanks Guy ,
that what i was told ...
any other alternatives for a high tourqe engine - especially for hill climb ??
any good race brand.
Nassim (Book#327)
Re: Double plate clutch kit
I don't have much info to go on here.
Often the Int 16v power is governed by the torque rating of the clutch. The highest rated bolt-on clutch I know is Helix and a 6 blade sprung cerametallic (ie: paddle) type. That can take 352lbf ft MAX.
The push type rating is lower, 280 I think.
If that is not enough the FW has to be machined to take a multiplate like this 200mm one.
I have to tell you that at these ratings sorting out a clutch takes a fair bit of time on my part and is not a 2 minute buy_on_line job.
And the cost of the package incl special release bearing can easily run into 4 figures (excl the decimal point). This usually comes as a surprise to the owner who has aimed for XXXXbhp and not thought at all about the ability of the clutch to take the intended output.
I am an agent for Helix and don't use any other makes. Have a look at Tilton Naz, be my guest! But I won't give advice on their products.
- GW_fitting FW & clutch (2).JPG (115.45 KiB) Viewed 11742 times
- GW_200mm cera sprung mod FW front.JPG (121.89 KiB) Viewed 11742 times
nassim131
thanks guy for this info.
can you please provide me with prices for these two types you mentioned , so my friend can decide which to go.
Nassim (Book#327)
not without knowing the torque output Naz.
Alternatively we get the strongest clutch poss and then dyno the engine and cap the boost so as not to overload the clutch.
I also need to know exactly which model this is - push type or pull type?
