Off topic: steam engine
Posted: January 8th, 2012, 6:29 pm
hi guys,
This is completely off topic and not much to do with cars but it's a pretty large engine, be it from another era. I just thought you might like to see it.
As most of you know, large parts of The Netherlands are below sea level; mostly lakes and marshes that we pumped the water out of. And to keep your feet dry, you then need to keep pumping every day.
That started back in the late middle ages with wind mills, today it's mainly electric and some diesel.
Normally all water is dumped into rivers and canals that somehow find their way out to the North Sea.
When there is too much water coming in and not enough flowing out, like when you're having days and days of rainstorms blowing in from the sea, then the water is pumped straight out into the sea.
During the last weeks we had a situation like that and it was all hands on deck. 'All hands' means Grandpa is called out of retirement. They fire up the Woudagemaal (Wouda pump station).
Commissioned in 1920 and named after the engineer who built it, this is the largest operational steam pump station in the world. It takes a crew of 12 men and some 6 hours to wake him up, and up to 11 hours to be running at full power. Normally he's run only a few days per year; for demonstration and to keep the machines in working order.
This week Grandpa meant business...
There are four boilers that provide steam for four sets of twin engines: all double-acting (steam working on either side of the piston: push/pull) and set up in high and low pressure teams. The steam coming out of the high pressure engine still has enough energy to drive the low pressure engine.
Each set of engines drives two massive vane-type pumps, making that eight pumps in total.
Running at full steam (literally!) this big boy displaces 4000 cubic meters of water per minute. Think about it... that is 4.000.000 litres of water being pushed up some two meters, every minute, around the clock. I make that an effective output of about 1300kW or 1800HP.
Steam engines are nice. They smell of oil, steam and hot steel. They hiss and rumble and click. They give off heat. And everywhere you look they sweat and drip. It's almost like they are alive. Big beasts.
Anyway, when I heard there was a general alert I gave them a call. Yes, it was running and yes, there were tours around the site. Took the day off, drove two hours up north, waited for an hour to get into a tour group and witnessed the beast going all out.
Some pictures for you, with descriptions we can all relate to.
I hope you guys like it.
