Fiat Punto HGT - Engine Rebuild
Re: Fiat Punto HGT - Engine Rebuild
My apologies for wording it so strong without any example. What I meant to bring across is that if you make drastic changes to your cam profile because you want a lot more power from your engine, you should have a head that matches the flow requirements from the cam.
Imagine your original engine is designed to give good torque between 2500 and 6500 rpm, peak power, 135 BHP around 6000 rpm. If you want that engine to give 190 BHP, you will have to make it go at least 7500 RPM, probably over 8000 and the usable torque will not be available under 4500 rpm. To get all that extra fuel required for the extra power burnt, you will need to be able to flow a lot more air through your ports. Putting a "fast" cam in a head that is optimized for the 135BHP example, will not make the head pump much more air, because the ports are too small. Going for an engine that will run 7500 RPM and above for substantial amounts of the time, will require a change to solid tappets. The weight and design of the hydraulic tappets will no longer be sustainable at that RPM rate.
From what I understand, you have a "fast road" setup now, that still gives considerable attention to low RPM drivability. My interpretation is that you want to get substantially more power out of your engine and the only way I know of doing that, without using a turbo or compressor, is going for the full race high RPM configuration. That is a totally different way of setting up an engine, hence my post about having to do a lot of work. I hope this makes my previous post more clear.
New rods finally ready...
440grams instead of 688grams Fiat ones...
H beam shape
This is my Christmas present :)
H beam shape
Finally ready...
Engine works fine, I have done around 200 miles
I will change oils and i will make an other 1000miles...at the end of the month i will go to my mapper to connect the idle valve and make some changes to fuel/ignition maps...
Almost certainly some combination of the above.
All the talk is that these engines are less amenable to tuning than the old Fiat twin cam and the 20v Coupe engine (which a few people have put into HGTs).
I think the final set of BTC Alfa 155s used the 2 litre version of the Alfa/Fiat twin cam -- the precursor of your engine. It would be interesting to know how much power they were putting out -- they were fast enough to be the car to beat.
GC_06
The 155 BTCC used a 16V head like on the Delta 16V and an 8V engine (no balance shafts). The head was reversed so the inlet ports would be on the front of the car. It's a totally different engine and the rebuild time on those was 30 running hours max. Usually, they would start each race with a fresh engine, or have it used just one race before. A 280 BHP figure for a 2.0 sounds impressive, but is not comparable to something you'd put in a car you are driving on the streets and that has to last for more than a week.fingers99 wrote:Almost certainly some combination of the above.
Try the (Dutch) Alfa 156 challenge, they had roughly 200 BHP from "almost street" engines and I know of a road car that had one of these engines put in after the competition ended. Almost street still means fully flowed head, custom cams, and custom exhaust. Mind you, that's a 2.0 and this HGT engine isn't. It is however almost identical, minus the CCs and 4 spark plugs for the Twin Spark in the Alfa.
At the middle of March when I was mapping the car unfortunately the head gasket blow from to high advance timing between water hole and bore and the engine flood of water.
I change the head gasket and the piston rings and now i have done around 800 miles, everything is fine.
I want to say a big thank you to my friend and engine builder George Sevdalis (Sevdalis SuperFlow Center) for all his help and support.
Engine bay
Damaged gasket
176 hp at 7400rpm and 19.1 Nm of torque at 6500rpm, poor colombo barianni cams - dunapack dynamometer - new custom MLS gasket to avoid failure again
If I change the cam timing with less peak power then I will hit 20 Nm of torque at mid range and a lot of faster car...but I will stay with the current setup for now
Nice result!
howewer.. I´m building 2ltr engine for my stilo 1.8 (because of lot of oil consumption and worn clutch)... as the block is the same as Alfa 2ltr TS engine...(instead of balancing shafts)
It utilizes stock Alfa/Fiat parts..
Barchetta engine block lowered by 0,6 mm due to lower CH of stilo abarth pistons
2ltr TS crankshaft
Stilo 2.4 pistons (will get higher CR, but not so Hight like 2ltr JTS in comparison to stock 2ltr TS pistons)
2ltr TS camshafts (has similar parameters like C&B medium road for 1.8 stilo), but with reprofiled intake one to 270°/ 10-10,5mm lift
AR 1.8 TS EU 2 headers (without cat),54mm pipe and stilo abarth backbox
Due to comfort functions of the car and communictaion between bodycomp. and ecu I will haver to use unichip for engine map...
I want to get near 165BHP.. and I see that it is possible.. from 2Ltr...it could be wery easier..
2ltr TS crankshaft
#100
