Alquati Cams ?
Posted: January 5th, 2010, 3:49 pm
by engineerted
can anyone identify these cams?
Alquati A44/5/M
Re: Alquati Cams ?
Posted: January 5th, 2010, 4:47 pm
I've got the list data on A-44/4M and A-44/6/M
but oddly - not 5M!
If you measure the nominal lift with a dti between centers I can probably figure out the rest. I think the M stands for Montecarlo so one probably has a drive gear for the inlet-side cambox mounted distr on that engine (not the same as Fiat 124..)
Re: Alquati Cams ?
Posted: January 5th, 2010, 6:28 pm
by engineerted
Thanks Guy, the nominal lift is 10.9mm.
Ted
Re: Alquati Cams ?
Posted: January 6th, 2010, 8:26 am
Alquati steel billet rally cam,from their old catalogue:
'Motori molto elaborati o rally'
28/68 68/28
0.3mm running clearances
Re: Alquati Cams ?
Posted: March 7th, 2013, 12:40 pm
by FiatRally
Hallo gents,
I see this is an old thread. This is what I am playing and learning about at the moment!
I checked the specs as my Alquati Book of 1984 states these cams as:
Lancia Beta MonteCarlo C148 Lift is 10.9 as new, yes.
The cam timing given as per Alquati is:
Asp. 48 - 67 and Sca 65 - 46
The A-44/6/M has the same timing with 11.3mm lift and used the C201 profile.
The A-44/4/M has been given as 40 - 80 and 80 - 40 with a lift of 10.35mm
A variant known as A-44/4/87m also exsist and given as 42 - 82 and 82 - 42 with a lift of 10.6mm
I hope this helps.
Ernst
