Lancia Beta aux shaft
Posted: October 10th, 2009, 8:27 am
by andrew
I recently aquired a 2.0 i.e. HPE to use as a daily driver whilst I'm restoring/improving my Montecarlo and as it's immediate history was somewhat unknown I decided to change the cambelt. I gave the job to a local garage as I'm just too busy with work commitments at the moment to do anything else. Big mistake... I guess from the thread title you know what's coming... The mechanic failed to time the auxiliary shaft pulley correctly and the shaft broke after hitting what I think will have been conrod number 2. In his defence he said he followed some timing information he found on the net and set the aux cog as per those instructions which were plainly wrong! I shall endevour to find out where he got the information from.
I have a spare shaft which I have now modified as per instructions in GC's book and given it to the garage to fit so that's not a problem. What I'd like to know is would anything else be virtually guaranteed to have broken/cracked/bent as a result of the impact or will he have got away with it? Apparently it happened immediately on the starter motor revolutions (I know... I totally agree... did he not turn it slowly by hand first...?) and the shaft snapped inbetween the bearings (I haven't seen it). Will the conrod have suffered? Surely it could've cracked the block around the inner bearing? Should I insist he strips it and inspects it? The last thing I want is a problem a few thousand miles down the road as a direct result of this when by that time I have no come-back...
A classic case of 'if you want a job done properly...'
Andrew.
Re: Lancia Beta aux shaft
Posted: October 10th, 2009, 8:57 am
Model Post!
This is one oddity of the TC engines of 79.2mm stroke or more (1800/2L) and I am pleased you wrote this thread!
It's always one of things I remark on when a client's engine starts 'knocking'.
The best way thing is get another, mod it as outlined and offer it up to the bearings and see how it feels. Chance of damage to the rod and debris in the sump? Remote.
Posted: October 10th, 2009, 2:46 pm
by andrew
Thank you Guy, you have put my mind at ease- hopefully there will be no further damage. If you're confident, I'm confident! I'll report back when I have received the car back.
Andrew.
Posted: October 13th, 2009, 2:49 pm
by andrew
Just got the car back and all seems well- running as before with no noise/vibration etc so it would seem as though he got away with it! Thank goodness the shaft is the weakest part of that collision...! Anyone reading this is well advised to do GC's mod as shown above and in the book; at least then you know it can't happen, even when you farm the cam-belt change out to a 'professional' who probably hasn't seen a twincam for a few years and has forgotten/doesn't know of this peculiarity.
Andrew.
Posted: October 13th, 2009, 9:59 pm
by Walezy
I would check the bearing on no.2 conrod. it might have been damaged when there was an impact.
Posted: October 14th, 2009, 8:58 am
Maybe a good precaution - but I would be very surprised.
