Distributor drive blanking plate
parrish
Post by parrish »
I am currently fitting a Programmable Engine Management system with Fuel injection to my Strada Abarth engine.
Geoff Wards article to be found elsewhere on this forum is invaluable.
I have a Guy Croft offset manifold to which i am going to first fit the Throttle bodies.
At a later date i intend to fit a more direct flow (straight) manifold.
This will require the removal of the distributor.
I am unsure as to what sort of blanking plate to fit to the distributor drive hole.
Am i right in thinking that i need something that will protrude down the hole?
Is their another drive down the hole that needs to be retained.
Are their any blanking plates available.
Steve
Parrish 366
pastaroni34
Re: Distributor drive blanking plate
Post by pastaroni34 »
I think you are referring to an application with a former block mounted distributor. If so you need a plug with sufficient length to retain the drive gear on the oil pump. These are available as OE Fiat items. If you need a plug for a cam box mounted distributor, you will have to have one made, or change to a cam box without provisions for a distributor.
In any case I have both available if you are interested, please email or private message for details.
-Jason Miller
Houston, Texas - USA
parrish
Post by parrish »
i think ive found one local, hopefully it will fit.
Ill be in touch if i need to.
Steve
Parrish 366
