Page 1 of 3
Fiat 131 Abarth Stradale Overhaul
Posted: May 29th, 2009, 12:00 pm
by RedLexus
Hi all , some time ago a good friend asked me to give his 131 AR Stradale a bit of an overhaul . The car was in decent enough shape , but after comparing it to my Dad's blue one he reckoned certain aspects of the car needed attention . It felt softer , looser almost , the brakes weren't as sharp , nor the acceleration , it had a few oil leaks , some rattles from the suspension and some other related issues . Typical of any older/classic car that has seen a fair bit of use .
So one fateful day I rolled up my sleeves and set to it . First I gave it a good drive , then put it on the Ramp and spent a while prodding and poking with a tyre-bar , seeing what was worn in the suspension and driveline . Several things came to light immediately .
the ARB droplinks all had some play , as did the outer front lower balljoint on one side .
Also the inner ARB bushings themslves were worn.
The rear was the same , with some movement on the ball joint on both sides.
The exhaust system's mounts were perished , letting it bang on the body .
There was obvious leaks from some of the Dampers
The Gearbox rear mount , the engine mounts and worst of all , the Driveshaft "Do-nut" were all worn , the Donut was actually torn!
Re: Fiat 131 Abarth Stradale Overhaul
Posted: May 29th, 2009, 5:19 pm
by RedLexus
The biggest problem I've found with this car is the pathetic availability of spares! Even engine mounts , which I had thought to be easily available was an issue .
We failed to get new replacement dampers , so we got them re-conditioned . Luckily (for me) the owner arranged that . Naturally I wasn't happy to refit the old looking items , so a quick spray job was in order . And a fresh coat for the coil springs too .
Then back to the ARB issues while the paint was drying . The supplied ones were gound to be completely wrong .....
so after much faffing around , I ordered some Polyurethane items for a Ford EScort and Capri , and with some small modification they were persuaded to fit . I had to change the hanger brackets from the Fiat to the Ford items . Luckily these were cheaply available , and only needed some slotting of the holes .
Posted: May 29th, 2009, 11:07 pm
by RedLexus
here's the modded ARB bracket. I would have preferred to use Fiat parts , but now we can have Bushings the next day for only a few euros , versus trawling Retro Fiat stockists for weeks .
Posted: May 29th, 2009, 11:26 pm
by RedLexus
I forgot to take pictures of the new ARB Drop links... again the only ones available were silly money , so bearing in mind my friend was trying to keep to a budget , I ordered 8 6mm Rose joints from a bearing stockist , a length of threaded bar (High Tensile) , and made my own . Rather than leave the threads exposed , I carefully measured a piece of 1.5mm wall steel, 6mm ID pipe , and slid it over the threads , between the top and bottom Rose joints . Stronger , and looks better too!
Posted: May 30th, 2009, 12:18 pm
by RedLexus
next on the suspension was the lower balljoints . The front was relatively simple I thought... Once I eventually found bottom arms! The were a 2 week search . When I found some , I bought 6 , in case our own two 131's ever need them .
The ordinary 131 is nearly the same , bar it doesn't have the brackets for the ARB drop links.
The rear , was a wee bit different... The lower balljoint is separate to the suspension arm , it's held in with 2 bolts . However as you can see the half shafts have to be removed to take the joints out .
In case your wondering , once I've everything tightened , checked , double and treble checked , I put a Tip-pex mark on the nut/bolt , so I know it's been done . And also so I can see if it is starting to loosen later on . And I always use Locknuts , unless it's not possible .
Posted: May 30th, 2009, 7:06 pm
by RedLexus
Balljoints and ARB bushes all done , next on the list was check the LSD . Or in this car's case, fit one ! This was the logical next step as the half-shafts were off . I was curious as to whether the OE Diff was in this car , so a pleasant surprise was had when I cleaned it off....
less pleasant was the amount of "gunk" found on the sump pan of the Diff housing . Any ideas what this forms from?
However , removing the diff was a doddle , with the halfshafts off , the entire side of the axle unbolted , the Diff came out with that , and then simply slid off of its splined shafts .
I transferred the ring gear to the LSD , fitted new bearings , and then re-installed it...and by sheer fluke , the back-lash and free play on the new unit was perfect! No need to move , insert , or remove shims!
heres a quick pic of the pinion gear . You can see the drive shaft the diff slides on to.
Rather chufffed , I sealed everything up , with a new o-ring and gasket compound , then filled it to the mark with Castrol B-373 LSD oil.
Posted: May 30th, 2009, 7:09 pm
by RedLexus
So , the halfshaftss , which are fully floating , ie they have a CV joint both ends , were carefully checked , and found to be ok , as were their Rubber boots . As a precaution , I swopped them side to side , so if there was any wear on them it would be cancelled out by turning the opposite way now .
Engine mounts next... these were as soggy as sponges! Random oil leaks plus a torquey , tall 16v motor had done them in . The owner supplied what were supposed to be OE ones , however they had a larger diameter , and the stud each end was 12mm , not 10mm like the ones I removed.... I suspect the new ones are a RWD Ford item ? Anyone recognise them?
I made a steel plate to help strenghten the mount , to help prevent the rubber sagging , basically a piece of flat plate folded into a very shallow "U" section . You can see it in the pic , between the rubber and the chassis mount , painted silver . It's the small things that count , I reckon...
Posted: June 2nd, 2009, 11:55 am
by RedLexus
Next thing to do was the brakes . I stripped all the calipers and pads off , and cleaned everything , no major issues . PAds were in good order , as were all the seals and so on . Some of the slides were a bit sticky , so a polish of all moving parts with fine sandpaper and re-assembly , then bleeding . While working on the fronts though , I noticed that the wheels were located solely by the Wheel studs , not with a central locating spigot . The Brake discs looked to have been machined too , as if the spigot was part of them , or something . Possibly to fit wheels at some stage thatweren't the correct fitment?
So some careful measuring up , and my Lathe/CNC equipped mate machined some natty adapter/spacers , one side locates into the centre of the disc and hub , the other side into the centre bore of the wheel . And they also space out the wheels a wee bit , increasing the track .
No such issues at the reart , the correct Abarth items were fitted.
Posted: June 2nd, 2009, 4:54 pm
by robert kenney
Common deposits from oxidation and heat when the differential oil is long for this world.
Posted: June 2nd, 2009, 5:23 pm
by RedLexus
Now..the bit you have probably been waiting for.....Engine dismantling!
Inlet manifold off..
Exhaust manifold off , and moved back away from studs , and 'Cam box covers removed
Cam boxes removed , because unlike the 8v Engines , the Head studs are under the cam boxes . Makes Cylinder head removal a bit labour intensive . In this picture You can see a socket extension reaching down to a Headstud .
And cylinder head off! You can just make out the valve cut-outs in the pistons . As you can also see , its a very similar block to the 8v.
all the bits!
Now , next thing to thoroughly clean the Head.
Posted: June 2nd, 2009, 11:20 pm
by RedLexus
A good wash with detergent , and steam cleaning , before removing the valves and springs.
I gave all the spring retainers a sharp tap with a plug socket and hammer to help unseat the collets , then laboriously removed all the springs , collets and retainers . All valves have double springs. Tired fingers after this job!
once all the valves etc were out , a good clean and examination of everything . These valves have a very wide seat , nothing fancy at all , the port has a mild porting job , possibly from original? I would have dearly loved to have sent the head to the GC workdhop for proper finishing , 3 angle seats etc , but sadly it wasn't in the budget this time .
I cleaned thevalves , and with the guides in decent shape all bar one , I lapped the valves with grinding paste with the old fashioned "sucker stick" . Times like this I remember why I prefer 8v engines...haha
Posted: June 2nd, 2009, 11:26 pm
by RedLexus
On valve guides , one was actually broken! at the top , where the seal sits on . So my preferred engine machine shop fitted a new one , and as you can see , gave the head a mild skim , to ensure it was properly "true" .
So then new valve stem seals pushed on with a socket..
and re fit the valves and springs , making sure that collets were accounted for!
I used some heavy grade engine oil on the valves , as I couldn't get proper assembly lube locally .
Posted: June 3rd, 2009, 11:50 am
by RedLexus
Posted: June 4th, 2009, 7:14 am
by ace124
Great pictures !
Im doing an 8 Valve head at the moment also and the similarities with the Abarth 16V are striking!
Seems your doing twice the work though! heheehe
Keep the pictures coming.
Great post
Posted: June 4th, 2009, 11:19 am
by RedLexus
ace124 wrote:Great pictures !
Great post
Tell me about it....calluses on my palms from the Valve grinding! All for a good cause though . The Head is very similar indeed to the 8v , apart from the headstuds hiding under the Cam Boxes.
