Cam and valvetrain questions Mercedes 2.3-16
Posted: May 28th, 2009, 8:30 am
Hello!
I am building me a better cylinder head to my Mercedes 2.3-16 engine. The head has quiet big valves from factory(38/33) and the ports are small and limiting the flow. In standard form this head flows 258CFM@28" in my bench or 153 converted to 10". The plan is to take up the ports, each port has separate channels that is 26mm in diameter. I am planning to take them out to 30mm.
The valves are going to be replaced, the intake valves is going to be 38.5mm and the exhaust will stay 33mm. Standard stem size is 7 and 8mm, and now they both are 7mm.
Now to the things that I am not sure of. I have bought a set of cams second hand, wich is not so easy to this rather rare engine. The seller said that they had an advertised duration of over 300 degrees. Before I bought them I convinced him to take a picture of the profiles and mesure the lift(12/11.5mm).
Looking at the picture I estimated the cams to be around 280degrees. I was almost certain that I knew wich profiles they had when I looked at Catcams homepage.
But when I got them they were engraved with a number wich I couldnt find at Catcams homesite, it turned out to be old profiles with a little agressive acceleration/ramp.
The thing that is obvious is that the differance in duration between 0.1 and 1mm lift is rather small compared to cat cams all other cams, just 24 degrees. Usally there is over 10 degrees more between this lifts. The cam specs for the Intake cam is 262(0.1,mm)/238(1mm)/12mm lift. The exhaust cam is 268/234/11.65mm.
One thing that looks a little odd is that the shape of the profile, there seems to be a pointy profile on top of the regularly looking one. The valve dosnt seem to dwell very long at 12mm.
The thing is that just a few more cams in their list comes close to thease values(Peugeot XU10J4RS 12.25mm lift), with 26 degrees differance.
Is this something I shall be worried about? Of cause the benefits is better driveability and low rpm range. The cams is used and still in newish condition. So it seems to have been working!
The thing is that I am going to use the OEM buckets wich in standard form has shim under bucket, but my new retainers dont have the support for that, so I will have to go with top hats or the valve stem directly against the bucket.
The benefits with the top hats should be that they distribute the load better to the bucket and prevents the valve stem to be hammered out.
The standard shim is the same size as the peugeot XU9 ones, wich i think is around 12mm in diameter. This way it feels better to have top hats to distribute the load better to the bucket. The area differance between 7mm and 12mm is quiet big!
The downside is of cause that the top hats can come off and that they whey more than the stem does.
What is your opinion on thease cams and setup?
I apply a diagram of the standard head flow.
Regards Gordon
Regards Gordon
