digiplex question
Posted: April 25th, 2009, 12:34 am
by midge
Can anyone please tell me if it is safe [ for the unit ] to crank the engine over on the key with the live feed from the ign switch disconected fom the coil ? I want to run a compression check on my Lancia delta engine without the hazard of the high tension sparks from the digiplex unit.
many thanks.
Re: Digiplex question
Posted: April 25th, 2009, 8:56 am
Quite possibly not. You should disconnect the coil and unplug the multi-pin socket from the Digiplex unit too.
Re: digiplex question
Posted: April 25th, 2009, 10:04 pm
by midge
Thanks Guy, good thing i thought to ask!
Posted: April 28th, 2009, 6:24 am
by SteveNZ
For a compression test, its better (and easier) to just unplug the crank angle sensor. There will be no spark or fuel injection.
Posted: April 29th, 2009, 12:03 am
by midge
Thanks Steve.
