Ford KA Rally Car Exhaust sizing help?
Posted: March 20th, 2009, 12:34 pm
by RedLexus
Hi all , I use a 1300cc Ford KA Rally Car with the Endura Engine (injected Ford Crossflow FWD), engine specs that I know of are ; bigger (single) throttle plate , fast road cam , mildly polished cylinder head , Motec ECU , with a 4-2-1 Exhaust system , running a single silencer . I need to build a new system , from the 2-1 collector back , what would be the recommended exhaust Inner diameter ? These engines in rally trim deliver approximately 90-100bhp . I normally rev it to 6500 rpm , top end power is not good at all though . I would like it to have most useable power between 4500 and 6000 . Thanks in advance.
Re: Ford KA Rally Car Exhaust sizing help?
Posted: March 20th, 2009, 12:40 pm
by RedLexus
I should have added , the secondary pipes are 38mm outer diameter , So I assume they are approx 35mm I. D ? and the current system is 45mm OD near the collecter , and steps up slightly near the rear section . I suspect the rear , from the axle back , including the (Janspeed) silencer is a "fast road" item . One rarely sees fancy rolled stainless/chrome trims on Rally exhausts!
Posted: March 22nd, 2009, 11:26 pm
by RedLexus
I did read the thread
viewtopic.php?f=1&t=4 "Fiat/Lancia Twin Cam exhaust systems" , and noted that in particular this quote "
If the manifold is a 4-2-1 I would go for secondaries of 25% larger than the primary and keep the same diameter for the exit pipe downstream of the secondaries." Going by that , if my secondary pipes are 35mm-36mm I.D . , that the 38 mm system should be ok? Or does the act it's not "straight through" , affect that?
Posted: March 24th, 2009, 4:07 pm
Can I have the ex valve size and port size please?
Assume ex port is circular?
Posted: March 24th, 2009, 6:05 pm
by RedLexus
Guy Croft wrote:Can I have the ex valve size and port size please?
Ah..I was afraid you'd ask that . I don't have those dimensions , the head hasn't been off , and no-body I've asked can tell me . Would the diameter of the primaries be any use GC?
Posted: March 24th, 2009, 6:21 pm
Take the header off and give me the port size only then.
Could you please email me with your Pat's phone no? (re the 16v unit).
BTW I know the exact cause of the 'walking cambelt' now but can't find the thread, perhaps you can and put the link here to save me time.
Posted: March 25th, 2009, 9:19 am
by RedLexus
here you go my friend .
viewtopic.php?f=6&t=1599&p=8358#p8358
