Removing distributor after fitting MegaJolt
Posted: July 17th, 2008, 12:08 am
The 124 AC.000 engine in my Sylva kit car is now running very happly on its crank pulley triggered Megajolt ignition system.
For neatness I'd like to remove the distributor from the block and plug the hole?
Is a simple plug all I need or does the oil pump drive rely on the bearings in the distributor for support?
If a plug will suffice, are there any from the Fiat parts bin that I can use, or do I need to have one machined to suit?
With the distributor gone, I could swap the sidedraft manifold from the current angled type to the "straight shot" type. Is there any advantage to be gained from this?
Best regards........Jonathan
