Fast road Monte - ideal CR?
Posted: November 19th, 2007, 8:02 pm
I'm after a bit of advice on CR for the twin cam engine I'm building for my Lancia Montecarlo. The car is used for 'spirited' road driving mainly, with the odd trackday / sprint.
The rest of the engine spec is as follows-
Gasflowed Volumex head (52cc chambers)
300deg 40/80 10.3mm cams
42DCNFs on Alquati manifold
Ansa 4-2-1 manifold, single outlet performance silencer
84.6mm flat top pistons
Block decked 0.9mm for pistons to protrude 0.5mm
The problem I have is that when calculated, the CR only comes out at 9.5:1. I was hoping for over 10:1, and ideally 10.5:1. Do you think this relatively low CR will be enough with the rest of the engine spec? Would I be better off leaving in the std cams with this CR?
Thanks in advance,
Nick
Thanks in advance,
Nick
