Page 3 of 4
Re: Lancia Dedra Integrale
Posted: April 3rd, 2008, 9:33 am
by hepe75
both adjustment caster/camper
centre part is rotating
Posted: April 5th, 2008, 5:42 am
by hepe75
Posted: April 5th, 2008, 5:44 am
by hepe75
Posted: April 5th, 2008, 8:41 am
Videos on Google, well done!
Some film hosting services are banned from this site, but Google I must look into!
What fun your films are, it's great to see some 'sound and vision' here, thanks!
Posted: April 19th, 2008, 4:14 pm
by hepe75
rebuild intake manifold
throttle body 70mm Dellorto
Posted: April 21st, 2008, 7:56 am
Wow you're skilled!
I'm very impressed indeed. Thank you for sharing your work with outstanding photos.
Posted: April 25th, 2008, 3:22 pm
by hepe75
Posted: April 30th, 2008, 10:07 am
by integrale
Hi hepe75.
What gear box you used original from Dedra or from Delta integrale?
And what clutch you used?
Regard Kiril
Posted: May 1st, 2008, 3:15 pm
by hepe75
I use orginal gearbox(it's same delta integrale) but I change rear differential from Delta integrale, because there is TORSEN and Dedra rear differential not
Clutch disc 228mm(orginal 235mm)
and clutch assembly is 30% more stiff to orginal
Posted: March 12th, 2009, 12:41 pm
by arjunior45
hepe75 wrote:Image
that's a piece of art! Congrats.
Wish I could make a couple of them for my Alfa Romeo 155 Q4.
you have a pm.
Nick
Posted: September 11th, 2009, 11:39 am
by Ev0luti0n_
Congratulations on the car and the job done! For sure a lot of money and expertise involved!
I enjoyed a lot viewing the pictures! Good luck with the car
Posted: November 10th, 2009, 8:14 am
by hepe75
I had a one-year break, for Lancia building...
but now i start building again
DIY
exhaust manifold + New turbo(gt 28 76)
DIY
intake manifold(not ready)
intake manifold & not painted exhaust manifold
and yes, the throttle should be in a different direction than usual
Posted: November 10th, 2009, 12:06 pm
I do recommend that you spend more time on the header and try to improve the ratio of chord radius to pipe ID. Ideally you want a ratio of 2:1 or better - in other words the most generous chord rad you can get. I've tested several aftermarket tubular headers lately from turbo 4 cyl units and the pressure drop due to adverse bends is very high - near 50% in some cases.
Posted: November 10th, 2009, 4:44 pm
by hepe75
I know that this is not perfect, but it has my own manufactured(first one ever) and the target is that it would be better than the original exhaust manifold is
Posted: November 11th, 2009, 8:02 am
As pre usual practice here my comments are constructive observations and not - criticism.
Without testing the original manifold you have no way of knowing whether yours is better or nor but be aware that it is easier to generate beneficial curvature with a casting than tube (in confined layouts anyway..) and it is a common misconception that pipe will be better 'per se'. It will not be if you have very restrictive bends like your layout has.
