Honza wrote:
It‚´s looking very interesting (and cheap) for me.You say that if I send you my original ECU ( 1995 Fiat coupe 2.0 16v non turbo - ECU 4Q4 blabla..I don‚´t know next numbers ) you will add some HW to make my ECU programmable and after this operation you send me ECU back with PC SW and communication cable for "only" 500Euro?
Hello Honza. Your ECU is IAW 4Q4/P8, and support for P8 series of ECU's will be available in 2007. At the moment, we only convert earlier series of IAW ECU's, like the one that was used in pre '93 Tipo 2.0 16v, or Integrale 16v (pre Evo2), or Ford Sierra Cosworth (known as L8 ECU in Cossie world).
P8 ECU's are made to meet Euro 2 exhaust gas standards, while the units we currently convert are designed to reach Euro 1 regulations. But with careful mapping, this shouldn't be a problem.
So, the best solution for you would be to get an early Tipo 2.0 16v ECU (IAW 4Q1 - WF4Q1.08) and send it to us for modification. Yes, we'll do it all for 500 Euro (excluding shipping). After conversion, the ECU will also support both speed density and alpha-N indexed fueling, so this is a thing to go for if you plan to switch to individual throttle bodies and/or performance cams at some later point.
You would also get one extra user configurable output, that you could set up to drive for example shift light, radiator fan(s) or to trigger NOS...
For extra 100e we can enable distributorless ignition - so that you can run coilpacks, or pen coils (coil on spark). This ensures more energy for spark at higher revs.
Honza wrote:because I must make new chip for every mod on engine and this operation isn‚´t comfortable for me and it‚´s very expensive (first custom chip - 600Euro , every next chip 150E).
Well, this point was not completely clear to me. If your engine is going to be custom mapped for 600 Euro, that's reasonable price (prices are usually higher). And especially if every next mapping session is only 150 Euro, this is a real bargain. Hopefully no one here would mind if I say that I'm used to see prices in range from 800-1500 Euro for this service!
Honza wrote:I have some small problems now, because in my chip I coudln‚´t move with idle speed and it very unpleasantly when idle is 1000-1100rpm at warm engine , I need idle speed between 1500-1700rpm when is engine warm.
Which cams do you use? 1500-1700RPM of idle speed sounds strange (i.e. too high), I must admit, because I used to park idle speed to 1250RPM only when using 300 deg cams. Which cams do you use, how did you make cam timing, how big is the valve lift at TDC? How much vacuum is your engine pulling while idling? It could be that your vacuum signal is weak for speed-density operation.
Honza wrote:This is lookin very well for me, because with this mod I could move idle to higher rpm and I could change maps cheaper after every mod on engine.And I could‚´t make new engine cable harnes with foreing senzors etc.
If you need to have idle targed speed changed even on your existing ECU, this is not a problem, we can do it for you (you'd just need to provide wanted setpoints across engine temperature range).
Honza wrote:If you change the HW in ECU,the standart (or tuned) maps and integrated functions will save in the modified ECU, or ECU is clean without any maps and integrated functions (immobilization system)?
I am not completely sure I understood the question here, but I'd try to give an answer. If I miss the point, please excuse me. So, when you get the modified ECU from us, it has start-up maps, that are developed for your engine, however, when in standard (unmodified) form. But these maps are going to get your engine running, so that you can tune your car. This way it is easier for you, than to start from blank maps - there are many calibration parameters in the ECU that could stay the same, you need to customize maybe 25% of the values.
Honza wrote:Can I tune modded ECU in my car over diagnostics connector?
Yes, precisely. All you do is connect the communication lead to diagnostic connector on one side and laptop on the other side, and you're ready to go.
Honza wrote:I know about one problem.I don‚´t know if you sent the ECU in to Czech Republic...
We'll ship to Czech Republic with pleasure.
Hope this helps,
Nikola Radenkovic
