Page 2 of 2
				Re: Augmenting Thermostat flow - Fiat Tipo 16v re-assembly
				Posted: May 3rd, 2008, 9:57 pm
				by SirYun
				Maybe you can use a V-band clamp type system to rejoin the parts.(like used on a turbo).  normally quite expensive but i could imagine that a similar clamping system could be made using a jubilee clip and some metal
				Posted: August 5th, 2008, 3:10 pm
				by Rich Ellingham
				Unfortuantly the araldite must have had a small void in it leading to some leakage on the join. Good news was that on the track it only ran at 80 degrees with 6 mm bypass.
I have re-drilled my spare thermostat with a 3 mm drilling without dissasembly. I had to use a carbide burr on the pillar drill to create a flat drilling surface inside the thermostat to radiator top hose exit, then I lined up a 3mm drill in the same place I drill before. I did not want to make a 6mm drilling as it was more difficult to align from the oppostie side of the thermostat face. I hope this will suffice.
Rich
