I have seen your shimming tool in your How to shim a SOHC head.
Is it possible to make a good picture from the side?
Maybe with some dimensions?
I ask because I had bought a tool from Fiat and this don't works.
It's a binder for the valve but then I need a second tool that the valve keeps down.
Your tool make this together and it's much easier to change the shim.
Thanks! Martin
Shimming Tool
Re: Shimming Tool
See photos, part numbers as shown, buy OE, you'll never be able to make one half as good.
- The pressure lever (so called) pt no. 1860443000 leans against the cam base circle to press the shim down
- SOHC_TC 8V_16V pressure lever at top and 16v 'positioning tool' for shim removal..jpg (112.55 KiB) Viewed 7955 times
- and this tool holds the bucket down to allow removal of the shim. Works OK if you are careful to place it properly, if you don't the bucket will break free and jam against the cam with no shim, requiring removal of the cambox to free it..
- Fiat X19 type SOHC shim tool 1860642000.JPG (151.75 KiB) Viewed 7956 times
- SOHC shim tool in place.jpg (157.05 KiB) Viewed 7955 times
Acki
Re: Shimming Tool
Hello Guy.
I have the first tool of you pictures.
Is the sencond tool of the same picture too hold the valve down?
I thought about laser cutting for the tool...
Re: Shimming Tool
That's right, it's curved inner edge slips under the cam body and it has special edges both sides to grip whichever bucket you're doing to hold the valve down. You can depress the valve with the pressure lever or just turn the cam to full lift to get it in.
Hope the photos help some.
- SOHC Fiat shim tool.jpg (114.9 KiB) Viewed 7917 times
- SOHC Fiat shim tool (1).jpg (114.11 KiB) Viewed 7918 times
- SOHC Fiat shim tool (2).jpg (114.64 KiB) Viewed 7921 times
- SOHC Fiat shim tool (3).jpg (112.04 KiB) Viewed 7918 times
