X1/9 1500 Head
PhilipModro
X1/9 1500 Head
Hi Guy and everyone,
First post on the forum so I thought I'd begin with a cylinder head I picked up from an internet auction site, which I know isn't really a reliable source but I will cut to the chase. I got it so I could get it modified whilst I continue to drive the car, but now as the car is off the road with a blown head gasket due to overheating (3rd time in a year) I am in two minds what to do as I would like to retain a standard head in case I want to switch it back over etc, the problem causing this dilemma follows.
The head I purchased off an internet auction site is in particularly bad condition (it only cost me £30) as there is lots of rust on the valve seats and valve guides, I originally wanted to have the guides changed and have new seats put in with 39mm valves which I hastily purchased given the opportunity but now am aware this may not be the wisest choice to maintain port velocity and therefore drive-ability at town speeds. This is for a hot street engine circa 140 bhp and as reliable as possible (whats your take on this guy?). Just seeking advice on what to do as I intend on fully rebuilding the car as it is riddled with rust etc, this re-build includes the engine, The car is a 1989 gran finale in mica blue with 80k miles on it. I suspect the current head is warped now from its overheating fests and the block may need decking also as part of the rebuild.
thank you
thank you
Last edited by PhilipModro on January 23rd, 2014, 3:28 pm, edited 1 time in total.
GC_72
PhilipModro
Re: X1/9 1500 Head
Here is a few pictures of that head.
Last edited by PhilipModro on January 23rd, 2014, 3:23 pm, edited 1 time in total.
GC_72
Re: X1/9 1500 Head
1. Beadblastand hot wash
2. All over deburr and inspect incl pressure-test & thread checks..
3. Gasflow
4. New race guides
5. New valve seats & cutting to suit big valves..
6. Reface
a straightforward but slavish ops list I do all the time.
The production pistons however will NOT accept larger valves and the problem of valve-piston proximity is compounded according to how much milled off the head (already or after true-up)...
3. Gasflow
4. New race guides
6. Reface
PhilipModro
Re: X1/9 1500 Head
Thanks for the fast response.
So new pistons would be needed for the bigger valves? I was considering this in the re-build anyway along with new bearing shells etc.
Would you recommend a standard 45 degree seat with maybe a 3 angle cut?
I have access to a flow bench here at uni (I am doing a degree in Motorsport engineering) however I have not used one before and only done minimal gas flowing on motorcycle heads, so I may send it to you for the gas-flowing as I am yet to get to that stage in my degree.
I assume this is all on your price list that's on the site?
GC_72
Re: X1/9 1500 Head
What you should do is buy the new GC book!!
Maybe your Uni would like a few!!
Re: X1/9 1500 Head
Getting your degree in motorsport engineering? Without sucking up to Guy, that is the best investment in your education you can make.What you should do is buy the new GC book!!
Re: X1/9 1500 Head
Philip
this is what you are up against on the SOHC with its inclined valves. Standard valves on the X19 1500 are 36/33mm.
The bigger the valves, more radical the cam, the more that has been machined off block and head the worse the problem.
The fact that this is a GC domed HC piston is neither here nor there...
- GT_BP285 dry build.JPG (117.33 KiB) Viewed 18849 times
- GT_BP285 LATDC.JPG (545.06 KiB) Viewed 18849 times
- GT_BP285 dry build (1).JPG (116.66 KiB) Viewed 18849 times
