Oil temperture and pressure - a preemptive strike
Post by miro-1980 »
One of your recommendations was installation of an oil cooler when building the new “racing” engine.
I am getting close to engine build and need to resolve the issue and get the parts.
I have a 15 row oil cooler (used). It was tested by a trusted local radiator guys and declared "air tight".
However, I now what happens when your oil cooler starts leaking oil while performance driving, and want to avoid the consequences of hot oil spraying on a hot engine .... (I do even dare name the consequences).
It looks like buying a new one is a much safer solution.
What size would you recommend. I was thinking of a bigger one than 13 row. (say 15-16 row). The engine is expected to get up to 180 bhp, and 13 row seems too small.
Secondly I need a sandwich plate. I am thinking about a thermostatic one , which prevents cool oil to be circulated through the oil cooler until the temperature is high enough and cooling oil makes sense.
Question: I have power steering installed and do not want to give it up. Will this in any way collide with sandwich plate /oil cooler installation ?) i
I as am I going to a standard (not dry sump) thus I need to think about oil pressure while hard breaking and on sharp/long curves at high speeds. I believe two things need to be installed :
- one: uprated the oil pump
- two: a big wing oil pan
Does it make sense – any suggestions/recommendations ?
Re: Oil temperture and pressure - a preemptive strike
Good quality photo of engine bay showing oil filter housing region please! Can't remember the layout with PAS.
Can't believe you're running PAS anyway! Why not remove?
Post by miro-1980 »
Guy ,
Here is the picture of PAS are of engine bay.
This is the space for oil cooler ( air intakes will be changed along with th aif filter box ).
space oil cooler .jpg (61.7 KiB) Viewed 10188 times
RE : PAS: I am an old man ... and love my PS while maneuvering on parking lots.
It really is a great convenience , fighting with no PAS during the summer days in a car w/o air conditioning in a driving suite , helmet , racing underwear - I get too hot and hate fighting with turning the wheel...
I know this is irrational and stupid , but this is how I like it.
M
PS:
Is this going to be the only sports car with PAS?
( I am not planning to install AC - thought roof air vent is under pasive consideration!)
Walezy
Post by Walezy »
I run PAS in my 131 also and it is a great help but I have only 1,7 turn from lock to lock.
Book#378
Post by miro-1980 »
Tomek,
I have standard 3.1 , though I know the abarths had 2.8 lock to lock.
