Fiat 131 Abarth S2000
Walezy
Post by Walezy »
I was supposed to write this post some time ago but never really had too much of spare time. right now i have so here it is.
short description:
-engine : f20c Honda s2000 standard engine - measured 246HP 2.0 liter N/A
-gearbox : quaife 6 speed sequential gearbox type 9 replacement with overdrive
-diff: 5,37 with colotti LSD
interior:
-FIA safety harness
-Race technology dash 2 gauge with DL1 Datalogger
Suspension
- Bilstein B6 with coilovers(all custom made by me)
-rear independent suspension
Brakes:
-Brembo 4 pot front 295mm x 30mm
-rear Lancia thema front calipers with 284mm discs but will be shortly brembo 2 pot with non vented smaller discs
-hydraulic handbrake
Chassis:
-group 4 tarmac bodykit
-Ireco Roll cage
Chassis will be replaced for a fresh one shortly as mine is already after 10 years of rally use so a "bit" worn
Some onboards from last rally that was in Czech Republic(Rallye Horovice) we made it 2nd in class and 12th in overall classification
http://www.youtube.com/watch?v=c3KSsort ... ature=plcp
http://www.youtube.com/watch?v=p7uqj4T3 ... ature=plcp
Book#378
DeltaDave
Re: Fiat 131 Abarth S2000
Post by DeltaDave »
Love it :) excellent
Walezy
Post by Walezy »
My car on special stages of Posazavi Rallye
http://www.youtube.com/watch?v=yf8-HgEO ... t_received
Book#378
Walezy
Post by Walezy »
21st of july was our lucky day, we have won Ceske Budejovice rally in A3 class(up to 2.0 liter) and we have been 6th overall with only few 4wd cars in front of us.
I have fitted in the rear Proflex Mcperson struts and right now i can travel much quicker, no more bumps as the suspension is now 3 way adjustable and i can fine tune it for high speed and low speed bump and rebound. This makes a lot of difference when travelling fast on a stages.
Here are some onboards
http://www.youtube.com/watch?v=PEO-g4ZI ... ure=relmfu
http://www.youtube.com/watch?v=7Fkd0O62 ... ure=relmfu
eWRC-results.com - results Rallye České Budějovice 2012.pdf
full results from the rally
(460.91 KiB) Downloaded 680 times
Book#378
Post by WhizzMan »
Whoa... that's seriously fast.
Walezy
Post by Walezy »
Unfortunately on the last special stage i had engine failure, probably i have a dropped valve on cylinder 4. I have not opened yet the engine but on monday I will order another engine and simply replace it, at some later stage I would like to take a look inside and maybe I will be able to make the engine with ITB fitted and use higher CR pistons. Will have to see how much it is damaged but i was able to make it to the service area in order to finish the rally. I have checked the onboard and logged data and i see no reason for dropping the valve, it happened when upshifting without overrevving the engine.
Book#378
Post by WhizzMan »
Aii... that sounds expensive. Be sure to match the compression with your cam profiles and fuel characteristics, or you will not gain anything.
Walezy
Post by Walezy »
Today I will order "new" used engine for the car so i do not care too much about tuning that new one, if it goes as good as the old one then it is fine, it has the power output at the level of VW Golf 3 Kitcar so enough for me.
I will probably take care of the broken engine to try to get a bit more power out of it but i think it will be very difficult as it had already 246HP out of 2.0 liter engine.
Here is another movie from that rally
http://www.youtube.com/watch?v=PMqaek9y ... ature=plcp
Book#378
Walezy
Post by Walezy »
I have opened the engine with broken valve and it is total disaster, everything is actually damaged. pistons are all damaged and one is completely smashed, the head looks exactly like the pistons so it will also be no more use of it. I have installed new engine and it goes like the previous one. Will have to check it on the dyno just to make sure all is fine.
Last saturday i have competed in a rally where i have unfortunately had some problems with axles as I have broken one of them and had to finish last stage with only one wheel driven so I got big loss of time on the stage. I also had to stop on the stage to check what happened as i got huge vibrations that I thought it was loose wheel but later on the service area it came that bolts from the prop shaft got loose.
Anyway I have finished 5th in class and 17th in overall classification, not happy about that but at least i have finished the rally.
http://www.youtube.com/watch?v=KyqgijLm ... ature=plcp
http://www.youtube.com/watch?v=ofeE8bpB ... ature=plcp
Book#378
Honza
Location: Lomnice nad Popelkou (60 north from Prague), Czech Republic
Post by Honza »
I will have to visit some rallye to sea this on my own eyes!
#100
Walezy
Post by Walezy »
Next rally is Svetla in about 2 weeks. see you there.
Book#378
Walezy
Post by Walezy »
http://www.youtube.com/watch?v=wJhzc1_F ... ature=plcp
This is a movie from Rallye Humpolec with my Fiat 131. This weekend I will be competing in Svetla Rallye in CZ
Book#378
Walezy
Post by Walezy »
http://www.youtube.com/watch?v=EkVEO90o ... ature=plcp
This is Svetla Rally, we ended 3rd in class and 11th overall but at the end of the season I am 2nd in class so not that bad as for the first full season driven with my Fiat.
Book#378
Walezy
Post by Walezy »
Small jump at full speed.
This photo can be given here as long as i put link to author website which is www.duben.org
Book#378
